Over heating - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 11-22-2011, 08:53 PM
Default Over heating
I have a 03 monte 3.8 l-36 I start the car it it runs fine after warm up it starts to knock as if there is no oil and when I went to check the oil level the dipstick was too hot to touch so I checked the temp guage and it reads normal why would this engine get hot like that after only running for 5 to 10 min is it possible that there is not enough anti freeze or air trapped in the cooling system.
Old 11-23-2011, 08:45 AM
Pop your engine cover off, open your thermostat bleeder valve and start the car. Get it to the point that coolant is flowing out of it and you'll know it's not air
When was the last time you flushed the coolant?
Old 11-23-2011, 10:28 AM
Blazed SS's Avatar
IT HERTZ
here is what it looks like
Old 11-23-2011, 10:31 AM
When I pulled the engine cover discovered that the plastic fuel line had melted after I repair this I will do a coolant flush I have never done a coolant flush since 2003.
Old 11-23-2011, 11:29 AM
Quote:
Then there is a good chance that the Dexcool (which at a MINIMUM should be flushed every 5 years, I do it every 2) is very thick and nasty right now.
I would drain everything, and circulate water through your system, drain the water, and repeat with water a few times. Then fill back up with a 50/50
Reply
Thread Thread Starter Forum Replies Last Post
Over heating problem please help chamberz Monte Carlo Repair Help 1 07-15-2009 02:02 PM
1997 Monte Carlo z34 over heating problem connersdad19 Monte Carlo Repair Help 14 05-29-2009 03:24 AM
Over heating sprfrk2005 General Monte Carlo Talk 4 05-20-2009 09:15 AM
over heating bjar61 Monte Carlo Repair Help 15 01-07-2009 04:48 PM
Tags
2001, 2003, bleeder, bleeders, carlo, chevrolet, circulating, circulation, coolant, engine, heating, monte, thermostat, valve, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
