Oil Pan Leak
Old 06-08-2012, 11:57 AM
butch049's Avatar
Default Oil Pan Leak
Might have minor oil pan leak heard this is comman in 3800 anybody had this problem? Thanks Butch Hard fix?
Old 06-08-2012, 12:50 PM
Pretty much every 3800 will develop an oil pan gasket leak at some point. It's a major PITA to replace since you have to drop the engine cradle to get at some of the bolts. I lived with mine leaking until I had the transmission rebuilt and the shop could get at it without any additional labor.
Old 06-08-2012, 02:20 PM
x2, mine has a small leak. I just keep an eye on my oil levels and make sure to clean the pan every oil change.
Either this gets worse and warrants the fix, or I'm waiting until I have to drop the cradle for something else so it can get done.
Old 06-08-2012, 08:01 PM
butch049's Avatar
Thanks guys that is what my buddy said today when changing oil .up on lift. Dropping cradle big job $. Thanks Butch
Old 06-08-2012, 10:12 PM
Maybe you could tighten the bolts a bit and get the leak to stop for a bit. I have done this on other vehicles before. Not too tight tho they will snap.
texan767
02-18-2015 04:38 PM
ezmoneybaggz
08-18-2013 10:44 AM
crete
11-06-2011 07:05 PM
koreancore
01-14-2009 04:59 PM
black2001montess
08-27-2007 04:45 PM
Quick Reply: Oil Pan Leak
