Oil Pan Leak
Pretty much every 3800 will develop an oil pan gasket leak at some point. It's a major PITA to replace since you have to drop the engine cradle to get at some of the bolts. I lived with mine leaking until I had the transmission rebuilt and the shop could get at it without any additional labor.
x2, mine has a small leak. I just keep an eye on my oil levels and make sure to clean the pan every oil change.
Either this gets worse and warrants the fix, or I'm waiting until I have to drop the cradle for something else so it can get done.
