4th Gen ('81-'88): No Power to the car at all
Was doing some welding on the car with the battery disconnected. After I finished I tried to the start the car and there is no power anywhere. No power to the dash or starter. Been reading that it might be burnt out fusible links? Help is greatly appreciated.
Checked battery all good. Even connected a starter and still no luck. All fuses under the dash are good. Found 2 fusible links near the starter and checked and if they get power and they both are good(meters light comes on before and after the fuse).
Hi `Jake,
What were you welding ? What area of your Monte ?
Did you check your starter ? Solenoid connection ? Have you had any previous problems on starting ? You can jump your solenoid connection by using a screwdriver between the neg & pos (?)
Good Luck & keep checking back to see what other member's post on your problem > Good Luck <
Hi `Jake,
Hi `Jake,
Sadly, I've heard of re-built & new starter being BAD Were there any arch's during the weld that could've fried the starter ?
Did you check for any burned wires (I'm sure U did, but I'm outa suggestions)...I hope that you can locate the problem...Keep checking back & hopefully one of our more knowledgeable member's can assist > double good luck 4>Sure
Hi `Jake,
Hi `Jake,
Happy that you found that problem & that you are also human...I've made a ton of mistakes working on cars & boat engine...I've learned from trial & error....More error's 4>Sure...
Look forward to reading more about your Monte + seeing updated pictures....EnJoy your running Monte Carlo + Life
ultrarevvin1
Vendor for sale section
01-11-2014 11:56 PM
kody02ss
12-28-2011 12:01 AM
tbmaniacal
11-29-2010 02:09 AM
