Need Help!! Alternator Replacement for 97 z34!
Old 03-24-2008, 05:22 PM
mattilus2121's Avatar
Default Need Help!! Alternator Replacement for 97 z34!
Hey everyone, first time poster. Just wondering how you guys accomplish a z34 alternator replacement. My haines manual doesn't really go into enough detail, thanks a lot!
Milford
Old 03-24-2008, 08:58 PM
Default RE: Need Help!! Alternator Replacement for 97 z34!
Well i happen to have a 97 ls im pretty sure they are in the same place and i have actully just replaced mine.. they are a little hard to do but not as hard as it hits the wallet... there should be about three bolts one on the front left and the others on the right hand side and a connector but before you tackle these bolts you need to remove the serpentine belt all you must do is simply move the auto adjuster back and the belt slips off now once you remove the bolts the alt should simply come out a thing i found out when you reinstall it there is hardly any room so i found it easier to put the bottom right hand bolt in first then do the top and the connector and then the easy one on the left slip the belt on tighten it down start it up and bam if your volt light was on hopefully it should be off now i hope this helped if it didnt i will go into more detail if needed Thanks for posting And have fun with the Z34
Old 03-24-2008, 09:09 PM
Good luck my g/f's old's had a 3.4dohc in it like that and you had to pull the wheel and the axel and go in from where the axel was. it sucked. i never did it on a monte but i think it would be the same...but i hope it turns out to be easier for ya, good luck again
Old 03-24-2008, 11:17 PM
Milford--
I'm not sure if the '97's had the 3.4 DOCH or the 3.8...if it's the 3.8 I can help you...otherwise just make sure your battery is disconnected! )
Old 03-25-2008, 01:19 PM
It is the 3.4l DOHC, the manual has me doing quite a bit like removing the exhaust lowering the engine etc. I have heard somewhere of someone removing right wheel and axle assembly and pulling it out through there black monte. I am going to attempt that route first because it seems to be the easiest. Thanks for the help guys and im sure i'll have more questions when I start!
Old 03-25-2008, 03:14 PM
Good luck...sounds fun
Old 03-26-2008, 08:17 PM
Ok I have the hub assembly, caliper, brakes etc off. Whats the best way of getting the CV axle out?
Old 03-29-2008, 01:26 PM
The cv axle is out, the alternator is free of connections and mounts but I can't seem to manuever it out. I have the tie rod end popped out but it looks like i'll have to remove the tie rod itself and my haynes manual doesn't say how to do that. help!
silverodo12345
01-06-2015 12:12 PM
Reaper101
10-08-2012 07:37 PM
esquire2021
04-18-2011 07:32 PM
esquire2021
04-18-2011 07:26 PM
badbob
08-09-2010 10:23 PM
Quick Reply: Need Help!! Alternator Replacement for 97 z34!
