Multiple cylinder misfire after washing motor
I degreased my motor and power washed it at a DIY car wash I've done this before but this time I sprayed the entire motor trying to id a leak afterwards I noticed the car was running rough I figured water affected the cool pack or plugs I throw a "multiple cylinder misfire code" I have not checked and inspected the plugs yet just trying to get other opinions on this.
I'm think new plugs since it's cheap
Condensation has probably formed under the boots of the plug wires. Pull the wires (one at a time) and dry the coil and plug ends. Another possibility is that the insulation on the plug wires has fatigued and the water created cross fire between cylinders.
How would you suggest drying them? I don't have a air compressor
05montecarloyo
08-08-2012 07:02 PM
menaja19
14
01-02-2008 09:21 PM
