Mass Air Flow Sensor Causing Car to Cut Off????
I have a 2000 Monte Carlo, recently my engine light came on in addition to my coolant temperature sensor and tire pressure sensor. My car started to cut off while driving and while at stop signals. I replaced the mass air flow sensor and was told my coolant temp sensor was broken. Though, my car CONTINUES to cut off and the car shop "cannot figure out the problem". Its been 3 DAYS and I am desperate for some advice. What sensor is making my car cut off??????
Does the car slowly lose RPMs and then hit about 500 and drop to 0 and stall? But if you give it gas it will stay alive?
I would say it's the Idle Air Control valve on your throttle body.
Wondering
6th Gen ('00-'05): Temperature Gauge Issue
grrttweaver
07-26-2013 11:55 AM
cbum1475
09-05-2007 08:05 AM
