Mass Air Flow Sensor Causing Car to Cut Off???? - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 11-09-2011, 01:52 AM
Default Mass Air Flow Sensor Causing Car to Cut Off????
I have a 2000 Monte Carlo, recently my engine light came on in addition to my coolant temperature sensor and tire pressure sensor. My car started to cut off while driving and while at stop signals. I replaced the mass air flow sensor and was told my coolant temp sensor was broken. Though, my car CONTINUES to cut off and the car shop "cannot figure out the problem". Its been 3 DAYS and I am desperate for some advice. What sensor is making my car cut off??????
Old 11-09-2011, 09:07 AM
Does the car slowly lose RPMs and then hit about 500 and drop to 0 and stall? But if you give it gas it will stay alive?
I would say it's the Idle Air Control valve on your throttle body.
Old 11-09-2011, 01:36 PM
Yes, I just checked with the auto shop and they're checking that now. They told me that my car cuts off when warm, but stays on when cold. Could that be the Idle Air Control?
Old 11-09-2011, 09:21 PM
I was just told that they changed the sensor for the idle air control and that my car is still "running rough"....I just don't know where to go from here
Old 11-13-2011, 10:03 PM
I would check the hoses running to and from the pcv valve for gunk , then put a new pcv valve in. I had a similar problem with my last car.
Old 11-15-2011, 09:57 AM
nemesis's Avatar
2009 Monte Of The Year
had some what similar problem it turn out to be a cracked vaccum line
Reply
Thread Thread Starter Forum Replies Last Post
Mass Air Flow Sensor Upgrade mavrickf1613 Headers/Intake/Exhaust 15 10-12-2013 01:25 AM
2000 mass air flow sensor? montecy Engine/Transmission/Performance Adders 5 03-19-2012 11:15 PM
Jet Mass Air Flow Sensor Install never4get Headers/Intake/Exhaust 7 05-10-2011 07:54 PM
Mass Air Flow Sensor Nova1585 Headers/Intake/Exhaust 3 01-12-2009 06:05 PM
jet mass air flow sensor slips96 Headers/Intake/Exhaust 1 05-25-2007 06:46 AM
Tags
01, airflow, car, carlo, connected, cut, cutoff, cuts, engine, installing, maf, make, mass, monte, off, sensor, wha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
