Mass Air Flow sensor bad?
Old 11-27-2015, 08:01 AM
delaislapr's Avatar
Awaiting Email Confirmation
Default MAF Sensor
Originally Posted by STUMPMI
Just a Little FYI...
To dbl check to be sure its the MAF...
Unplug the MAF ...start it up and drive it...
If the problem disappears, Then its definately the MAF...(For testing purposes only) Not recommended to continue to drive with it unplugged...
If the problem persists...Then it has a whole other issue.
I dont think you can do that cause if you unplug it the car will cut off.
Old 11-28-2015, 12:22 PM
plumbob's Avatar
It should stay running. It just bypasses the signal sent to the PCM to adjust for lean/rich conditions. If you disconnect it and don't notice any change the MAF may be bad.
Old 03-18-2017, 10:19 PM
Glad to hear... It was a relatively simple fix..and Happy to hear...Your back up and running!
Were here to help...
I'm having the same problem as we speak. I have a 2000 monte with a 3.8. The problem started about a week ago. At 1st It would idle really rough but then go back to normal. But recently the car has been cutting off while Im driving.it would let me go about 5 miles then idle really rough then cut completely off esp.at a stop sign or red light. At 1st I thought my car was just overheating and just cutting itself off to stop damage to the motor.but it wasn't until today I was outside trying to figure out what the problem was...my girlfriend comes out the hse and tells me to unplug the MAF and see if the problem stops. .I guess she did her own research or she a mechanic by night 😂but surely enough the problem disappeared. So I'm going to replace the MAF tomorrow.
Miss_Carlo88
11-17-2018 12:16 AM
mavrickf1613
10-12-2013 12:25 AM
never4get
05-10-2011 06:54 PM
Nova1585
01-12-2009 05:05 PM
slips96
05-25-2007 05:46 AM
Quick Reply: Mass Air Flow sensor bad?
