Mass Air Flow sensor bad?
MAF Sensor
Just a Little FYI...
To dbl check to be sure its the MAF...
Unplug the MAF ...start it up and drive it...
If the problem disappears, Then its definately the MAF...(For testing purposes only) Not recommended to continue to drive with it unplugged...
If the problem persists...Then it has a whole other issue.
I'm having the same problem as we speak. I have a 2000 monte with a 3.8. The problem started about a week ago. At 1st It would idle really rough but then go back to normal. But recently the car has been cutting off while Im driving.it would let me go about 5 miles then idle really rough then cut completely off esp.at a stop sign or red light. At 1st I thought my car was just overheating and just cutting itself off to stop damage to the motor.but it wasn't until today I was outside trying to figure out what the problem was...my girlfriend comes out the hse and tells me to unplug the MAF and see if the problem stops. .I guess she did her own research or she a mechanic by night 😂but surely enough the problem disappeared. So I'm going to replace the MAF tomorrow.
Miss_Carlo88
11-17-2018 12:16 AM
