L67 build
Keep your engine the l26 does not have forged anything. Buy a used turbo kit for around 1,600-2,000 off of club gp of grandprixfprums.net
Get the tune that goes with that turbo kit and buy a front power log if the kit don't come with one. That's about it. No need for a northstar on a turbo setup the stock tb is fine. If you add a cam etc and max the stock maf buy an afc and scale the stock maf back is all. Just my .02
Really though, if your intent is to stay with a M90- why not keep the bottom end you have and just top swap it? The increased compression will let you spin the SC slower than a similar power, lower compression build. It'll be operating in a more efficient range.
L67 are rated 240hp stock, so I figure about 220ish fwhp
I want to get new heads, is there aftermarket heads I can get for it that aren't 1000$. or should I have them bored?
Honestly, if you're only looking for 300whp, I don't think you really need heads. A turbo would be the easier route- but on a SC setup, the higher compression NA bottom end with the cam and a full size IC (along with the other usual supporting mods- headers, etc) should get you in that range rather easily.
I would love to just go buy a turbo kit, but that's almost $5000!
Also, if you're concerned about the $5000 price tag for a top of the line turbo kit, look at the price of what you're planning on anyways:
-engine/trans $500
-full stock rebuild of both $1k +
-cam w chain and springs $500
-heads $1000-2000
-zzp TB/MAF $300
-headers $500
-tune $300
-injectors $300
-ported blower $300
-MPS/pulley $100
-ported LIM $50
That's $4850 right there using the cheap heads and a low estimate for a full engine/trans rebuild. I realize some of the prices are off a bit- but you're easily in the $5k ballpark with what you're wanting to do, especially by the time you throw in fluids, belts, and other misc parts
Get a l32 engine instead of the l67 engine. The l32 have the genv sc. If you have to swap the genv onto a l67 you need lower intake for the genv also.
Originally Posted by BrandonStebing
So your saying I should just get a turbo kit? What other mods would I or should I get with it? And where would I look for one, what would I search, and what exactly should I look for
Originally Posted by vikesfan
get a S3 3800 n/a (powder forged pistons IIRC) and drop it in
i also am using the stock trans without issues, and i dont drive like a grandpa either.
I also don't see any benefit to swapping an L36 to an L26 unless your stock engine is really beat, in which case I'd just find a used L36 bottom end in good shape since they're more plentiful anyways.
IMO a stock trans is not a good idea at 350 whp. Not saying it won't work, or you couldn't get away with it- but to the OP: you should definitely have money set aside for a built trans if you're planning on making that much power. These transmissions are well documented for not holding power well at all. You certainly could slap a turbo on your current setup, and just drive it until it blows the trans; but hopefully you have a DD in that case so you can still get to work.
EDIT- Here's a couple of quick pics of an L26 that just let go a month or so ago:
i would say that the turbo, if possible, is the way to go for sure. you dont have to work "as hard" to make the power that someone with a s/c does imo.
what i would do....
adapt N* tb and LQ4 maf to S3 upper intake
find used turbo kit and install
this should run you about $3000
drive it till the tranny goes then buy a built transmission. i would suspect that you will need a trans sooner than later though.
that is another $2000-$3000
if money is tight, just do the top swap. you could easily do that for less than $500 on the low end.
what i would do....
Don't even bother with the ebay turbo "kit". The turbo is garbage, and if you have to ask what else you need, then you obviously don't have the tools/skills to fabricate the parts to finish the kit anyways. If you're going to pay a shop to fab the rest of the parts for you, you're quickly going to close in on the price of a ZZP Z3 kit, and you're still stuck with a no-name garbage turbo.
If your budget is less than a Z3 kit, then I wouldn't bother with a turbo at all. I'd look into doing a top swap since they're dirt cheap nowadays, or just leave it alone until you save up for a turbo and have the money at least set aside for a trans.
Perhaps you missed what I had typed above. Go to ZZP's site, and search for the Z3 kit. Base price for a bolt on kit is $2350. You're not going to find a cheaper bolt on kit with a real turbo unless you go used.
pretty sure there are powder forged rods or pistons as verified by bumpin below along with numerous posts on clubgp and other sites.
i would get a turbo kit just like you said if funds are available.
Whatever you do, DON'T get an L26. They're powdered metal, and not a real forged rod in the traditional sense, so the strength difference is not drastically different from a cast rod. However, the L26 has a horrific record of blowing up the bottom end on modded cars. If you don't believe me, search for yourself over on clubgp.
i guess when i did my research in december and january, there where as many people f'ing up s2's as there were f'ing up s3's.
there is going to be engine failures no mater what. sure there are two pics that show blown up motors, but i am sure i can hope on over to any of the many sites for 3800's and grand prixs and will find 2 people that had their s2 motors go as well.
there are also plenty of people that are pushing a lot of power from the s3's, so i am not sure what to tell you. based on my own personal experience with the s3 block, its been working just fine with my top swap and i havent exactly been nice to it either, driving and/or the tune.
there is a failure rate on any engine. personally, for the money, i will stick with the s3 motors. mine had like 80k and was only $250.
and do NOT get the chinese ebay turbo's or kits off of there. there are plenty of good turbos for sale on there, but you are taking a crap shot. just dont do it. also, there are no "universal" kits.
just get a used one as previously mentioned.
Swap Complete!!!
Question. I swapped an l67 motor & trans out of an 98 gtp into my Monte carlo ss. Well the l36 trans I took out had an internal neutral safety switch, and the gtp had an external switch. I was wondering if anyone know what I can do. I scrapped the gtp.
You are now no longer talking top swap if I understand your post.
