L67 From 03 Bonneville SSEI swap?
So the engine in my 01 ss has had a number of issues and now has a bad knock. I was mulling different options and my father called today to tell me his 03 Bonneville ssei's frame is rotted, he wanted to know if I wanted him to look into how much it would cost to swap the engine/tranny out of his car since they work perfectly into my car.
So basically, is it a direct swap for the l67 from his car into my 01 ss?
We have every part from the Pontiac since it is just going to end up being scrapped anyway.
Thanks!
Thanks!
Trans no, engine yes. Would need to do some wiring etc though and a new tune. Other than that you should have everything. Engine mounts you would reuse from your car since the Bonneville uses different style mounts etc
I think trans has different electronic connectors. You could swap the diff if you wanted since the ssei has the HD and yours has the regular one.
What parts are you talking about swapping to upgrade yours?
I was thinking the diff lol, my father used to work at a shop in town and he talked to them and they start work tuesday!
I'll update this thread with results!
