just blew my engine. what is needed for a l67 install
I have a question for you bumpin I did a 3.8 n/a swap from my 3.5 to that 3.8 right now I got a flex plate from a supercharged one to see if it would start and idle. it did but I don't want to hurt my trans. would that weight do that much damage? if I drove it around the block. I do have a set of supercharged heads cam and right now saving to get a good remand supercharger. would the supercharged flex plate do harm? I wanted to ask because I know the internals of my 4t has the double chain and majority of what the hd has because I asked the shop to put the best in. but I wanted to ask because of the work you have done to your 3.8. plus I wanted to get input from you because of that good looking thing you have
Probably wouldn't hurt anything just idling or driving around the block, but why bother? It's a ton of work to change it to the right one so just do it right the first time. I wouldn't screw with engine balancing at all unless a machine shop is rebalancing the entire assembly or you're deleting the balance shaft (which isn't for primary balancing and is net zero to itself).
