How to get rid of knock?!
Holy sh**. Does that price include the lube?
500 for cam AND install kit?? where?! Lol man, I thought 1700 was cheap! I looked online and all the parts ill need for the cam are right under a thousand. tune here would cost me about 400 and I haven't found anyone that would do the install for less than 1200! lol
the lube? Lol
no idea how many hrs it would take for a cam install plus tune. I'm guessing maybe 18hrs? that's kinda what ive been hearing
the lube? Lol
XP HOT Cam from ZZP - $324.99. Install kit from ZZP - $109.99.
Camshafts & Valvetrain
Just scroll around and see the prices of different cams. Good luck with your decision.
the lube? Lol
the lube? Lol
Taken straight from ZZP's XP Hot cam page.
Designed and used by Chris White, the Competition cams X-P HOT cam is designed for supercharged or nitrous applications on 96 and up GM 3800s. The XP cam produces higher WHP and torque numbers than any cam grind currently available (that can be used with stock heads).
* Notes:
This cam (and any cam with a lift of over ~.515) requires upgraded valve springs and modified retainers for safe long term operation on stock heads. You can run higher lift than that with stock valvetrain but you're asking for trouble. Down the road you will be using oil as your valve seals become prematurely worn. When using the stock timing chain and dampener, the 105's are recommended over the 90# springs because they will give less wear on the dampener and are a better spring in general.
Think you're going to be OK because another company told you so? Check this out:
"I had this installed last summer, and to my knowledge, I didn't need any machining on the guides to have this cam installed. Car soon started to use a little bit of oil it never had prior. It got to the point of about 1 quart a week, so took it apart sure enough the new seals were all chewed up the lift on the cam was to big and they were coming in contact with the guides."
"I had the same problem too last summer, So I called and got a new set of viton seals, and didn't have a problem since then. Unfortunately I had to park my gp about 3 weeks after switching over to the news seals for problems unrelated to the cam. And ya mine was using about a quart a week too."
"Also have the same cam and have to add a quart of oil every other month or so."
Those are just a few situations that we pulled off of the message boards. Users were misled by another company into thinking that they would be safe running a higher lift cam w/o properly setting up their car for it. Six months to a year later they found out the hard way that you couldn't. It's easy to sell cams with big numbers and promise big gains, but part of modifying a car is doing it in such a way that your investment will last. This is why we are very up front with what to expect with our cams and encourage owners to Email with any questions you might have before making a purchase.
Look for gains of 40-55 hp depending on your car's current configuration.
212°/224° at .050"
Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
116 Lobe Separation
* Notes:
212°/224° at .050"
116 Lobe Separation
This modding thing is such a hassle
Thanks for all the info though guys! Just out of curiousity, how many monte's do you guys know of that are cammed? Here in MN there arent many whatsoever. I dont even think ive ever seen another modded monte to be honest lol
Will be ordering X-P cam instead of s1x cam, and will update pics and vids once installed
