car tunring off quick responds plz!
Old 07-01-2013, 08:12 AM
sprfrk2005's Avatar
Default car tunring off quick responds plz!
Got a 2001 monte carlo ss with top swap I have prob with it turning off as soon as I put it in gear or give it a little gas what can be the prob?
Old 07-01-2013, 08:19 AM
What do you mean.."Top Swap" ??????
I think were gonna need a whole lot more information to even begin to try to help you.
Old 07-01-2013, 08:25 AM
sprfrk2005's Avatar
Top swap meaning 3.8 na made into a supercharged
Old 07-01-2013, 08:51 AM
I believe theres a PCM swap that needs to be done as well a tune!
Me personally Im not to up on a swap of that kind... Mines a N/A...3800
Did you swap the PCM? and have it tuned for the supercharger?
Old 07-01-2013, 03:33 PM
turbo monte's Avatar
stumpmi is correct, you need to have the pcm tuned for the top swap....
Old 07-03-2013, 08:11 PM
sprfrk2005's Avatar
OK let me rephrase that I have a 2001 monte carlo ss with a 3.8 sc was working fine then out of no where the rpms started going crazy up and down then it stalled out. I go to restart it and it just cranked but no start after like 5 times it started and as soon as I put it in drive bam stalled out. So I left it there for a day and came bck and bam the same thing rhen I placed it in reverse and working like a charm so I try drive again and shuts off as I tap the gas. So now u have a better explanation of my situation pleaseeeeeeee hhhheeeellllppppp
Old 07-04-2013, 12:26 AM
I think we still need some more info here... You have a 2001 with a 3.8 sc that was working fine. (I'm assuming this wasn't the original setup & it's what you put in the car?) If you added a S/C did your PCM get changed? How long was the car "working fine" and what mods were done to it prior?
Old 07-04-2013, 01:10 AM
sprfrk2005's Avatar
I did the swap 2 years ago pcm was tuned and had no prob. Untill about a week ago. Please read my previous reply this post for synthoms
2000montecarlo
01-30-2012 09:33 AM
sprfrk2005
03-22-2011 12:20 PM
hrg
01-25-2011 12:03 AM
01MCSS52
09-23-2009 10:30 AM
yd0502
14
02-23-2007 05:22 PM
Quick Reply: car tunring off quick responds plz!
