im @ a loss
Old 03-24-2011, 12:56 PM
alkj29's Avatar
Default im @ a loss
I have a 7th gen MC... I recently started experiencing the low oil pressure light coming on, service tms indicator, service air bag (once)..the most annoying right now is low oil pressure..this starts mainly after driving highway speed.. it seems to happen when hits hot after driving a period of time.....Any thoughts.....
Old 03-24-2011, 03:54 PM
Budsjlm's Avatar
did you check your oil level? when is the last time it was changed? what weight are you using? and finialy conventional or synthetic
Old 03-24-2011, 04:16 PM
x2 is your oil level actually low???
You might be having some faulty readings from the BCM just throwing codes at you.
Old 03-25-2011, 12:25 AM
alkj29's Avatar
it acually started almost immediately after getting oil change @ a quick lube joint... about 1500 mi ago.. oil level is fine thats the first thing i checked
Old 03-25-2011, 12:27 AM
alkj29's Avatar
recomended oil and weight right now.. this started after oil change @ a qiuck lube joint..yes lvl is fine
Old 03-25-2011, 09:55 AM
I would go get it changed again somewhere else and see if that helps, if you can't do it yourself.
Old 03-25-2011, 10:24 AM
Cowboy6622's Avatar
Sounds like it is either burning oil or has the wrong weight in it to me. Maybe it has gotten older and needs to use a higher weight, higher mileage oil.
Old 03-25-2011, 04:59 PM
your supposed to be running 5w30 i dont think its a weight issue. some of the guys i believe on tech had this issue before. i believe it was a sensor. go to ls1tech and do a search in the ls4 section. that is if its an ls4 car.
The Popcorn King
FWD Tech Guides '95-'07
05-26-2008 06:31 PM
big_mecho13
02-14-2008 08:17 AM
BLACK ATTACK
01-01-2008 05:39 PM
lisacan2
01-15-2007 12:27 AM
Matthew
06-19-2005 03:25 AM
Quick Reply: im @ a loss
