Electric choke on my new carb
i put on a new 600 cfm carb with a electric choke and a vacuum advance distributor, everything is hooked up except the choke, it said to connect it to the key accessories but idk where that is, is it possible to connect to the ignition wire going to the distributor? i got a black wire, a yellow wire and a red wire the goes into it.
year? motor ect?
if it is a 4th gen there is ignition spots on the fuse box you can see the ign and arrow next to the ecm fuse and one next to the turn signal fuse
just ignore my finger in the pic that was to show the bat location!
loudNproudSS
04-25-2008 10:27 AM
