Leaking from valve cover? W/Pics
Old 12-16-2009, 01:30 PM
prez's Avatar
Default Leaking from valve cover? W/Pics
Trying to figure out if this is leaking from the valve covers, it happens on the front and back of engine. You can see where it pools up in those crevices, I figure it is the valve covers, cause if the head gasket was leaking wouldn't there be antifreeze mixed in?
It's leaking about a half a quart every two weeks, and smells terrible after driving it. How hard is it gonna be to replace those gaskets on the valve covers? assuming that is what you all think it is? The help is very much appreciated, taking a road trip around Xmas and want to get this fixed ASAP.
the top pic shows the oil "line" where the oil usually sits, but it has burnt up, the second pic shows one of the crevices full of oil.
Old 12-16-2009, 01:32 PM
prez's Avatar
Also forgot to add its the SS 3.8L, naturally aspirated.
Old 12-16-2009, 03:28 PM
Are you SURE it's oil and not dirty anti-freeze? Soak some up with a paper towel- I'm willing to bet it's anti-freeze.
It's probably a bad lower intake manifold gasket- this is a really, really common failure on 3800s. It's not a bad job to tackle yourself. A shop will charge $300-600 for it.
Old 12-16-2009, 10:32 PM
prez's Avatar
Smells like oil, feels like oil, and burns like oil. After driving the whole garage smells like burnt oil.
Old 12-17-2009, 12:38 AM
prez's Avatar
After researching further I see the intake mani gasket is a big problem. Would it possibly just leak oil out of that, or antifreeze for sure? It's full and not leaking antifreeze 100% sure.
Old 12-17-2009, 09:21 AM
UPPER intake manifold leaking?
Those are also quite common (and a great time to buy and HV3 :cough cough
dbaldwin
42
03-19-2014 06:51 PM
farmerjg
02-14-2013 09:25 PM
blueSS
03-29-2012 08:58 AM
adreed24
02-10-2005 02:24 AM
Quick Reply: Leaking from valve cover? W/Pics
