control module inside intake?
when i popped off the air filter and the heat shield i found some type of control box inside of it...can anyone tell me what it is and what i can do with it? i dont think i can screw it right to the metal of the car considerin i then ground it and will prolly short it out...any suggestions?
RE: control module inside intake?
its sounds like your describing your PCM...
http://cgi.ebay.com/ebaymotors/2000-...spagenameZWD1V
im guessing it looks like that?
http://www.wbodystore.com/grandprix/pcm-tray-p-151.html
this is what i use it is the best one that i have seen also it is the cheapest. i have it in my car and it works perfect. All you have to do is drill some holes to mount it.
7498MonteCarlo
09-13-2010 10:09 AM
glenn
05-18-2009 10:15 AM
