Conflicting T-Stat Info
Old 09-15-2010, 10:13 AM
Originally Posted by 03SS/00GSE/93LX
I run a drilled 160 now in mine. It's really not bad at all. I programmed my fans to accomodate the 160 and it really helps with heat soak in the summer. I also think it prolongs transmission life, as my trans fluid stays about 20* cooler too.
How's your fuel mileage? Operating temp for 6th gens is 170*F and the computer will be running the fuel system in open-loop until operating temp is reached. The computer will run the afr (air-fuel ratio) richer to warm up the enginer quicker until you get to op temp; then the outputs of the O2 sensor, etc will be valid. Above 170*F the computer will then try to maintain a proper afr.
I'm not trying to be rude if you already know this -- I just figure people contemplating 160*F t-stats should be aware of what's going on. Plus, I live in Winnipeg, Manitoba where it gets to -40* in the winter and I don't even want to think of having a 160*F t-stat then, lol.
Old 09-15-2010, 10:31 AM
Gas mileage is the same as it was with the 180* t-stat.
Absolutely not true. Stock closed-loop enable is 43* F- I just chcked this by looking at my stock .bin.
There are other AFR correction functions in the PCM, but these are time based, not ECT based.
I do agree that a 180* thermostat is a better choice for most folks, but I want my junk as cool as possible when sitting in the staging lanes before making a pass.
God_Bot
FWD Tech Guides '95-'07
03-06-2013 12:42 AM
Super Strong SS
03-24-2010 08:20 PM
03SS
11-11-2008 10:15 PM
v8_Killa
08-31-2008 06:55 PM
derrel96ls
05-04-2007 09:41 PM
Quick Reply: Conflicting T-Stat Info
