No more traction control?
Old 07-08-2010, 09:08 AM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Question No more traction control?
Ok guys, I have finally come to the point where I have done enough mods to the car that it is worth taking to the track and seeing what its got.... The only problem is, when I get on the gas hard, the traction control kicks in with the button switched on or off.... So what I was wondering if there was a fuse I can take out or a diff way to disable the system all together (just for the track of course). Thanks everyone ahead of time!
Old 07-08-2010, 09:28 AM
Sounds like one of your sensors is partly disconnected, or dirty.
Take a look at all the wiring going to your wheel hubs.
Old 07-08-2010, 11:57 AM
Photobucket
I want to disconnect the system all together for a short period of time..... any help on how to?
Old 09-11-2010, 12:27 PM
Photobucket
Does anyone have any help with this? Im really getting sick of not being able to break the tires loose no matter if the button is on or off! Thanks!
Old 09-12-2010, 10:51 AM
Only one way to do it- disconnect one of your wheel speed sensors. Just unplug the wiring harness for your track time and plug it back in when you're done. I usually do the rear drive side wheel.
As you've found out, pressing the button in the cabin only disables the braking portion of TCS- the ignition timing retard function is still active.
Disconnecting one of the wheel speed sensors will totally disable the TCS system, as it shorts the TCS sensor loop. It'll also disable ABS. I do it every time I go to the track and it works perfectly.
Old 09-12-2010, 10:57 AM
Photobucket
Thank you very much, that was the answer I was looking for!!!
Old 09-12-2010, 01:43 PM
No problem at all! Glad I could help...make sure you post your track times after you go.
Old 09-12-2010, 03:39 PM
Photobucket
There not going to be good, I just wanna go to see the before and after diff after the turbo install
Old 09-13-2010, 07:36 AM
Well an easy way to get it permanently disabled is to get stuck in mud then have a tow truck twist your frame when they pull it out...
Old 09-14-2010, 09:42 PM
When you do that, does the "trac off" light, abs light, and a message that says "service traction system" come on?
Quick Reply: No more traction control?
