Check Engine Light - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 02-07-2010, 03:31 AM
Default Check Engine Light
Ok I keep getting a large evap leak DTC. P0455. I can clear it and it will stay away for about a week. Usually it kicks on when the car is first started and then will remain on...sometimes if I don't clear it, it will go away on its own after a day or two...but it will return. I have changed the fuel cap with an OEM one as the one on the car was an aftermarket one.
Short of spending $80 for someone with a smoke machine to diagnose this thing, any ideas? I hate to throw parts at it but a couple quick things may be worth it.
The car runs perfect with the exception of a transmission issue that I need to address soon.
Old 02-07-2010, 04:55 AM
Wilco's Avatar
You may want to check this link possible solutions. I noticed you already replaced the gas cap but did you check to make sure the cap has a seal present? If the cap is OK then a vac leak may be the culprit. Check all the vacuum hoses, specially the ones going to the evap canister, for leaks. Good luck!
http://www.obd-codes.com/p0455
Old 02-07-2010, 02:05 PM
perlgurl's Avatar
I am having the same problem. My mechanic doesn't have a smoke machine (small mom and pop shop) but he checked the entire system looking for bad hoses/leaks/etc and never found anything. He did replace the gas cap but we're waiting on a new OEM fuel line to be shipped in (unrelated issue) so don't know if the cap has solved the problem yet. Thankfully since he doesn't feel he fixed it he's not charging me for all the time spent looking through the system.
I think I'm going to have to go to a shop that has a smoke machine.
If you find out what the problem is please post
Old 02-10-2010, 02:24 PM
this could be the sensor in the fuel tank attached to the fuel pump. even if you had a leak in you evaporator. i wouldnt care about it. if you want it fixed your probably going to be replacing the pump. so if i was you, i wouldnt care about it.
Reply
Thread Thread Starter Forum Replies Last Post
brake light/abs light/low brake fluid light hotrodharley Monte Carlo Repair Help 2 11-15-2013 12:37 PM
Car surges but no check engine light? J_Bru_Ha_SS Monte Carlo Repair Help 29 07-30-2007 10:08 PM
Check Engine Light BeachBumMike Off Topic 2 09-21-2006 11:48 PM
reset check engine light malletboy Monte Carlo Repair Help 3 05-28-2006 07:07 PM
check engine light rich131 Monte Carlo Repair Help 9 12-16-2005 03:07 AM
Tags
04, 2000, 2002, canister, carlo, code, evap, leak, located, monte, p0455, po455, ss, vac, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
