FUEL problem
Old 11-04-2012, 08:19 AM
Michael Rooney's Avatar
Exclamation FUEL problem
I have a 2000 monte with 292000 miles running perfect and my fuel gauge doesnt work when i first start the car it says i have a full tank then after about a min max it reads empty any suggestions on how to fix this?
Old 11-04-2012, 09:04 AM
MAMONTE's Avatar
Your fuel pump sending unit is probably bad. I would suggest replacing both the sending unit and fuel pump at the same time. This will more than likely fix your problem!
Old 11-04-2012, 09:20 AM
X2
Old 11-04-2012, 05:38 PM
thank youuuu!!!
Old 11-04-2012, 05:46 PM
Sending unit and fuel pump are easy to change ,Glad GM put the trap door in the trunk..LOL
Slamjunk
09-29-2014 03:56 PM
ReaperSS
08-29-2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
01-26-2014 05:54 PM
robknight13607
03-20-2013 09:14 AM
MJClemm
03-18-2013 07:10 PM
Quick Reply: FUEL problem
