Boost hose install via firewall?
Hey so i picked up a boost gauge that i want to install after i did the super charger mod on my 3800n/a from zzp
It's a 2002 and I'm trying to figure out how or where to run that hose from, and where to plug it into, I'm assuming one end will plug into the t fitting leading out from under the snout into the boost gauge but most importantly how to get that dam hose thru the car lol
Thanks
Thanks
I made a T off of the map sensor on the back of the motor so it was less line to run. I'll suggest going out and buying some black good quality vacuum line to do this with. I used the clear hose that came with my gauge and it got so hot and had so much vacuum that the hose actually melted itself shut.
As for running it inside, I think I popped a small hole in the firewall near that large bunch of wares that come through already, and then used a rubber grommet around it. Then just run it up through the drivers side fuse box and into the A pillar.
you should be able to T into any vacuum line and it will work (works like this on a turbo car anyway) as enzo said i also ran through the firewall where all the factory harness goes in. its at the bottom of the firewall pretty much straight down from the alternator.
01 Monte SS
10-23-2012 09:31 AM
nycemsmedic67
06-26-2010 04:34 PM
musclecarfreak1235
09-18-2009 10:09 AM
w where is the hose coming out of the firewall for the windshilWhere on my car does this thing exist
mordis41240
12-27-2004 07:43 PM
