98 Monte ls 3100 Antifreeze leak - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 04-17-2012, 07:36 PM
Default 98 Monte ls 3100 Antifreeze leak
Car started overheating, noticed that my antifreeze was running low I had filled it just a week before. I fill it up again to find the leak, it is coming from the left side of the engine by the pulleys but not the waterpump farther back towards the top but cannot see it only see it leaking pretty heavy out of there. Hoses are good, radiator is good, waterpump is good, thermostat is good and housing. The oil is not mixed with coolant. I just cannot figure it out. Any Ideas?
Old 04-17-2012, 09:32 PM
Got a pic or anything where the coolant is pooling? Not to combat your assertiveness or anything, but if it truly isn't all the things you said it isn't, you've not left yourself many options. Lower intake manifold gasket possibly? You'd hardly be the first Chevy to have this issue.
Old 04-17-2012, 10:09 PM
zzapultimate's Avatar
LIM gasket would be my guess. Very common issue.
Old 04-18-2012, 12:18 AM
Does anybody know if the 3100 has the coolant elbows ? If it does check them to
Old 04-18-2012, 02:15 AM
I will try and get some pictures, Its very hard to tell because it is leaking down and out its kinda behind a pulley but is not behind the waterpump pully.
Old 04-18-2012, 10:40 AM
My wife's 3400 LIM was always leaking internally then about three days before we got married it finally started leaking externally. I gave it to her dad when we left for Hawaii and he took care of it while we were gone; worked out great.
Anyway, point of that statement, when it finally started leaking externally I couldn't figure out where it was coming from so I dried up all the coolant then stood there and watched it run for 10 minutes and sure enough I was able to see the coolant come out between the intake/block interface. You may just need to stand there and watch it.
Old 04-18-2012, 11:40 PM
the 3100 does not have those retarded coolant elbows. 99% chance it's the l.i.m. gasket. replace right meow.
Old 04-19-2012, 11:02 PM
3100 does not have coolant elbows.
Usually a water pump failure leaves a nice WET line right above the serpentine belt on the hood insulation. If you're not seeing anything there, probably NOT the pump.
Best thing to do, with the car cold and a radiator pressure tester (hit up the parts store for a loan-a-tool), pump it up and LISTEN for hissing. To be honest, based on the description provided, my thoughts are lower intake gasket (the coolant ports on on the far outsides of the intake, it's NOT uncommon to have it blow in a manner that most or all coolant exits the engine and never enters the oil). If you use a radiator pressure tester, look where the LIM and heads meet, you'll probably see coolant escaping.
Reply
Thread Thread Starter Forum Replies Last Post
antifreeze leak mr202monte Monte Carlo Repair Help 4 12-20-2010 11:10 PM
Antifreeze leak mitch520 Monte Carlo Repair Help 8 04-19-2009 09:59 PM
antifreeze Sir Monte Monte Carlo Repair Help 4 02-20-2008 09:08 PM
help!!!! antifreeze leaking!!! hotrodss24 Monte Carlo Repair Help 10 12-24-2007 10:58 AM
Antifreeze leak 87lsman Monte Carlo Repair Help 1 06-06-2007 02:56 AM
Tags
3100, 98, blown, carlo, chevy, coolant, elbow, elbows, intake, internally, leak, leaking, marlo, monte, pullys, radiator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
