3400 cam.....
adding a cam isnt that difficult. its to each there own. there, i said it lol. like i also said, just get one of these:
http://www.youtube.com/watch?v=b9XAC...layer_embedded
Dave had 275whp with an NA 3500 in a cavalier.
I would also imagine that the setup is pretty much maxed out as is NA, without getting into real expensive stuff- would I be somewhat correct in that assumption? That is kinda my point- that these engines are small displacement- the heads are limited by fairly small valve flow area being a 2V setup- and there isn't much aftermarket wise you can do about either- so making big power NA isn't overly practical.
I'd also imagine for the kind of money he spent on that NA build that he could've done a IC'd turbo for about the same price and made at least the same power gain with plenty of room to spare for future modding and much more power? (I'm assuming that the bigger turbo 60*'s are making somewhat similar numbers to the bigger turbo 3800's).
It's a bone stock 3500 bottom end, ported top end (done by me), Comp cams 26915 springs, 75mm TB, 36lb injectors, home built longtube headers (1 5/8" diameter, 32" long) and a custom ground cam (.539 in/.549 ex, 288/293 advertised duration on a 110 LSA).
The engine build itself cost me less than 2K and made 275 WHP and 259 WTQ on 89 octane. The car ran a 13.07 @ 107 MPH last fall on slicks weighing in at around 2900 lbs with me in it. Search Youtube for "3500z"
bumpin96monte, it's not maxed out. With the excellent port flow of the 3500 top end there is still more to be made. My heads currently flow around 240 cfm @ .5 lift on the intake side.
The engine is going into a '89 Camaro with a 3500 stall and a 4L60E trans this summer. I might push it a little harder after that.
As for the 60 degree leghumpers comment... Regretfully i owned a 3800 once. It did a great job at weighing down the back of my truck last winter. After that i dumped it off at the scrap yard with the rest of it's burnt friends. :p
Gotcha, must insult everyone, not a single person.
Unfortunately, I do think that this thread has become a bit OT though- we went from comparing a guy wanting to do a cam swap on a 3400 vs a L67 swap (which the OP had been considering) or some sort of turbo kit on his engine to trying to compare a fully built, very custom 3500 setup. For example, bob442 was saying $700 for a 25 hp gain, so a $1000 for a 32k mile L67 for a 60 hp gain is in the same ballpark- albeit with an extra day's labor.
I got the 3500 for $610 with 678 miles on it from a local scrap yard.
You are correct in that i did do much of the work myself, however depending on the circle of people "your average person" means different things. In my circle we do engine swaps, porting, trans work, mandrel bent exhaust systems, headers, chassis work, body work, etc...
In the J-body world we are used to the lack of aftermarket parts, if you want something you gotta build it.
Yes, it's a HM282 (Muncie) 5 speed. 15-17% power loss which is much better than an auto trans. it also only weighs 60 lbs.
Stock 3400 swapped 5 speed Jbodies put down 190-200 WHP all day long with a good tune and a good exhaust system. I've watched and tuned several on the rollers. With a mild cam and mild port job we were able to get 224 WHP out of one. There is another cammed 3500 Jbody running around Iowa who is making almost the same power as me and it's daily driven.
The gen3 60v6 is a great engine, I've been in the GM FWD community for a very long time and there has always been this little battle between the 90 and 60 owners. Both engines can be built to make great power. The 90v6 has a more established aftermarket and more people willing to throw money at it. Since it's production has stopped and the 60v6 has taken over in a large amount of GM cars you are going to start seeing us come out of the woodwork.
As for more power, now that my flowbench is working i'm going to touch up my heads, bump the compression up to 10.3:1 with some thinner headgaskets and possibly run a ITB intake if the owner and i can work out a deal. I'm also building new headers since it's now in a RWD app, with a better collector design and better overall system it should pick up some power in the top end.
My 3800 comment was a joke too.. lol
but seriously, it worked great. Much better than sand bags because the ice seems to break them open and make a mess.
(I added + parts to the engine swaps since either way you're going to need at least some minor parts). Plus you obviously add reliability with a nearly new engine with either engine swap. Sound about right?
(maybe you should post up an intro thread with your setup, I'm sure lots of people would like to see it- and it would keep the questions from getting too far OT in this post?)
Eastern Iowa..
I gained 120 HP over the GM posted numbers with a cam, headers and port work. That's pretty decent any way you look at it. The OP could do similar if he's willing to spend the cash.
He's got a great flowing top end as it is, putting a decent cam in there to make use of it is a logical way to make more power. Of course he could gain more with any number of other parts but the foundation is there. I'm sure of he joined up over at 60degreev6.com we could help him in the right direction. I've built and helped build lots of these engines, there are 4 in my garage right now.. lol
While i've certainly considered boost, I decided a while back to push this N/A build as far as possible before i went there. I did just finish porting a 3500 top end for a local guy's Beretta. He's shooting for 600+ HP with boost using a HM282 trans. It's a 3400 block, stock cast iron crank, forged H beam rods, forged pistons and a nice boost cam from wot-tech.
FWIW i hold the record for the fastest N/A V6 Jbody, which is sad because i was never able to get a good launch or 60' time. If i could hook up 12's wouldn't have been a problem. I could have daily driven the car too, at one point i was getting 35 MPG on the highway.
http://www.youtube.com/watch?v=g8d4cVC0xgU
http://www.youtube.com/user/whitelightning2
Some videos.
Some videos.
