6th Gen ('00-'05): What is TCC Slip?
Tcc slip is the amount of slip the torque converter has. When I was on the Dyno mine was slipping like 300 rpm which is terrible and probably hurt me an easy 40-50whp. Generally when tcc slip gets really high your torque converter is on it's way out the door, you can bump up line pressures in the tune to help but that's only a bandaid
