4th Gen ('81-'88): Looking for ideas on what to do to my 350 engine
I'm looking to swap a 350 crate engine in place of my stock 305 just looking for ideas on heads, intakes cam etc. to use as I rebuild the 350 any input is highly appreciated
Depending on what you have for compression an heads you might be able to do a simple rebuild with a good cam/intake/carb an make some good street able power. If the heads are to small you might have look into getting a set. Aluminum is better than iron an there's a few that you can get for a decent price.
KINGBASS
03-17-2015 03:45 AM
78monteman
06-22-2010 12:03 AM
